What kind of lube is best for installing bottom end bolts?
HarleyMick
Rock Hill, SC 29730
Putting the Titan Stroker back together after replacing cam bearings, etc. What kind of lube is best for installing bottom end bolts? Crankshaft, etc. It will affect the torque, right?
No I really can’t recommend anything particular in your case.
Is contacting Titan an option in case they used a speciality fastener?
When I’ve reassembled a bottom end with stock fasteners I’ve just used 30w motor oil.
Reactions: Daryl
I spoke with tech support at Titan Engines and they said to use assembly lube on the threads unless a manufacturer like ARP or Comp Cams specifies a different product.
Sounds good. Did they give you the torque spec(s) to use?
If I remember correctly (it’s been a while) the ARP product was more graphite based.
Use non metal anti-seize or moly lubricant, I work for an race engine builder and that is what we use.
Thank you so much! I never want to see these bolts again. All I want is 6,000 smooth, strong RPMs.
ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container
