What part do I need?
Big_Red
Colorado Springs
Hi everyone! I just bought my 2004 TJ Rubicon. I knew from the test drive that it was missing a part to hold the shifter boot in place. I installed a new shifter bezel but that is clearly not the only part missing. What do I need?
Thanks, I already installed that part but it still doesn't stay in place. The shift boot has a bezel in that picture.
if you already have the plastic bezel then that's all you need. Are you sure you are installing it correctly? If I recall there are notches that go in then snap it down. I would also check to make sure the console top isn't damaged
Might be silly, but it is directional. Make sure it's going the right way.
EDIT: i have a 2001, newer one's might not be directional.
