T The mule New Member Joined Mar 26, 2020 Messages 5 Location Buffalo,NY Apr 3, 2020 #1 What size Tori's bit would you need to remove stock mirrors for a stock 2000 TJ?
cliffish TJ Expert Supporting Member Joined Oct 22, 2017 Messages 5,365 Location St James, NY, United States Apr 3, 2020 #2 it is called a torx bit..
OP T The mule New Member Joined Mar 26, 2020 Messages 5 Location Buffalo,NY Apr 3, 2020 #3 cliffish said: it is called a torx bit.. Click to expand... Thanks, you are smart.
cliffish TJ Expert Supporting Member Joined Oct 22, 2017 Messages 5,365 Location St James, NY, United States Apr 3, 2020 #4 The mule said: Thanks, you are smart. Click to expand... not really, if I was smart I would know what size..it is raining now here in lower NY or I would have gone out an checked the size for you. Just buy a set, you will need it with the TJ.
Jerry Bransford Too many arguments and personal attacks, I'm done. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Apr 3, 2020 #5 Our TJs use pretty much all sizes of torx head hardware, you'd be better off just buying a complete set up to and including a T-55.
RaymondT TJ Enthusiast Supporting Member Joined Aug 13, 2016 Messages 711 Location Sunshine Coast, BC Apr 4, 2020 #6 T27. I've seen some cheap sets that skip this size.
