T The mule New Member Original poster Joined Mar 26, 2020 Messages 5 Location Buffalo,NY Apr 3, 2020 #1 What size Tori's bit would you need to remove stock mirrors for a stock 2000 TJ?
cliffish TJ Guru Supporting Member Joined Oct 22, 2017 Messages 6,228 Location St James, NY, United States Apr 3, 2020 #2 it is called a torx bit..
T The mule New Member Original poster Joined Mar 26, 2020 Messages 5 Location Buffalo,NY Apr 3, 2020 #3 cliffish said: it is called a torx bit.. Click to expand... Thanks, you are smart.
cliffish TJ Guru Supporting Member Joined Oct 22, 2017 Messages 6,228 Location St James, NY, United States Apr 3, 2020 #4 The mule said: Thanks, you are smart. Click to expand... not really, if I was smart I would know what size..it is raining now here in lower NY or I would have gone out an checked the size for you. Just buy a set, you will need it with the TJ.
Jerry Bransford No Longer Participating Supporting Member Joined Nov 9, 2015 Messages 29,734 Location Fleming Island FL Apr 3, 2020 #5 Our TJs use pretty much all sizes of torx head hardware, you'd be better off just buying a complete set up to and including a T-55.
RaymondT TJ Enthusiast Supporting Member Joined Aug 13, 2016 Messages 718 Location Sunshine Coast, BC Apr 4, 2020 #6 T27. I've seen some cheap sets that skip this size.
