Ok changed tranfer case fluid ATF 4 .
Checked third member it was low fill with 80W 90. Checking u joints and notice just a little play in pinion bearing. Not much enough to see. Well I'm fixing to tow it on a trip. I think it will be ok. Any thoughts on that. I could undo the drive shaft,but all that would do is save my transfer case if the rear end had a major failure.
