Hey boogieman, I like your new avatar!I don't have it and would never want it.
Pretty sure my 06 unlimited does not have smart brakes
My understanding is that there were none sold with Dana 44 and disc brakes. So if you got a trim or package that includes a disc Dana 44, then you won't have abs.
My drum brake Dana 35 99 Sahara had abs until I Dana 44 swapped it. My disc Dana 44 06 Unlimited Sport never had it.
TJ Rubicons and Rubicon Unlimited models never had ABS.
As for non-Rubicon models, some of them had it, while others didn't. It was an option, and it ill be very apparent if they have ABS by looking under the hood and seeing the ABS module right under the master cylinder.
Sitting on the tray under master cylinder? The empty tray where I mounted the ARB compressor?
That's where it would be if were there?
So, when I replace my rear stock Dana 35 with an ecgs D489 (non-capable ABS) do I have to do anything extra or just experience an extra light on my dash. thanks in advance. 2000 sportYou're correct, ABS later became available for the rear Dana 44 too. I should have included that.
Nothing extra is required, your ABS system just won't work any more. Removing my '97 TJ's ABS relay turned the ABS light off after installing a non-ABS rear Dana 44 but I have read that doesn't work on later model years. I hate lights being on so personally I'd pull the instrument cluster out to pull the ABS bulb or if it's gone to LED by your model year twisting it out or cutting its connection.So, when I replace my rear stock Dana 35 with an ecgs D489 (non-capable ABS) do I have to do anything extra or just experience an extra light on my dash. thanks in advance. 2000 sport
ABS was available on all years as an option.04 X, Dana 35 No ABS
