Been trying to track down an annoying rattle coming from the tailgate and narrowed it down to the top left tire carrier bolt.
I have the Rugged Ridge Spartacus HD Tailgate Hinge and the Spartacus HD Carrier. Both are in the queue to be replaced with a Bestop HighRock 4x4 Swing Away Carrier, but I fear the damage is done. The hinges are fine, but no doubt installing the swing away carrier isn't going to remedy the issue with the rattle.
All the carrier bolts are tight but if I apply a fair amount of hand pressure to the spare I can hear that the top left bolt is making a noise. With hand pressure it sounds like a click, but on the road it's a rattle. The spare isn't in jeopardy of coming off (famous last words) but I don't want to ignore a potential problem.
So, what's going on inside the tailgate? Are the carrier bolts going into some kind of nutsert? @AndyG suggested thru bolting which Is certainly a viable option, even with the change to the swing out carrier. I like the idea because when I install the swing out carrier I am installing the Bestop Overtire Cargo Carrier too so the added reinforcement wouldn't be a bad thing. If I went the thru bolt route I think I would drill out both upper bolts and use a single backing plate on the inside. Worried about water infiltration or worse, accumulation in the tailgate interior. Any other options? Maybe remove the RR tire carrier and spot weld the insert?
I have a vid of the clicking sound but for the life of me can't figure out how to post it. I suck at the inter web
