What's this LJR worth (tricky one)
BShephard
ND
What do you guys think this LJR will go for?
It's an 06 six speed with 50k.
Has a Salvage title and some undercarriage "issues".
Check out the pics and let me know what you think.
  • Wow
Reactions: 04 LJ
Did the motor mounts break at the frame or the block?
Is the transmission OK?
Did the fan hit the radiator?
You need fuel lines, brake lines, wiring, new skid plate,
I'd be concerned about hidden rust under the dynamat.
Pull the seat covers off and check the seats. Pick every minor issue apart and then offer them 5,000 if the motor and axles, and transmission are good.
Did the transfer case case brake off? 🤔
I'm not sure, looks like some serious carnage under there though.
Tough to say, I'd have to go look at it I suppose. 5k seems about right though.
From the looks of it, that had to have been a pretty rough 50k miles.Too many un-knowns here,
3 thousand tops.
