Wheel Question/Opinion
Roadhand01
Georgetown, TX
My lit TJ is pretty much stock with the exception of the wheels and I believe the chrome bar.
My questions to you are,
1. I am pretty sure the spare wheel is stock, so this is a canyon wheel?
2. I believe I found a set off a 99 that look undamaged. Would you replace the chrome ones with the canyon wheels and remove the chrome bar? Leave it?
What don't you like about the chrome wheels? Do you just want all matching wheels?
I get that you don't like your wheels. Just keep your tire size in mind. I don't know the backspacing of the oem, but make sure your tires will fit without rubbing. You might need aftermarket wheels or spacers for the OEM. Definitely not worth it if you need spacers.
Good point, thanks.
It had a 3" body lift and 33"s when I purchased it and a couple of worn tires
Knowing I was going to remove the lift, I bought 31x10.5s. My tires may not want to fit the smaller rim.
The spare is 30x9.5
You should be ok, I have 30x9.5 tires on ravines and it's not even close to rubbing. Canyons I believe are the same size wheel, 15x8 with 5ish inch backspace.
Remove the chrome nerf bar.
Reactions: Plumber1
