I installed Motobilt Hiline fenders on my LJ and can't figure out where the washer jug will fit. I have a Derale TJ spec fan kit. The overflow attaches to that. I also have cruise control. Can I get some pics of what was done to keep them?
What pumps the fluid ?Replace the reservoir with a windshield washer bag and zip tie it to the radiator support rod. That's what I did and it worked great.
This is similar to what I used.
A windshield washer pump. They're cheap and the one I bought even plugged directly into the TJ's OE washer pump connector.What pumps the fluid ?
Thank you Jerry. You are always so knowledgeableA windshield washer pump. They're cheap and the one I bought even plugged directly into the TJ's OE washer pump connector.
P.S. IIRC the OE water pump fits perfectly into the bottom receptacle of the above bag.A windshield washer pump. They're cheap and the one I bought even plugged directly into the TJ's OE washer pump connector.
Yea, that's pretty cool. I'd rather have an electric pump, but I'd be perfectly fine with a foot pump as well. As long as it doesn't have a microprocessor, touchscreen, or smartphone involved with it I'm good!And I bet @Zorba approves.
