Where is the turn signal flasher located on a 2001 Wrangler?
Jeep&Jerry
Lenoir North Carolina
Reactions: TDB55 and Blondie70
Pull the “clam shell” trim around your steering column off, directly behind the steering wheel. It will be on top of the column between the wheel and the instrument cluster.
Reactions: Blondie70
Remove the three screws that hold the clam shells together. Remove the top clam shell from the steering column, you will find square relay plugged into the multi function switch (controls your headlights, turn signals, flashers, and windshield wipers).
https://www.amazon.com/dp/B00G0ONW32/?tag=wranglerorg-20
