I've been looking at Marine radios, just in you get caught in rain with no top/doors
https://www.crutchfield.com/p_113KM318BT/Kenwood-KMR-M318BT.html?tp=61742
Shwane that 40 RMS watts on the Sony is per channel, not total. Each of its four channels puts out 40 RMS watts for 160 RMS watts total.
Lovemachine, RMS is the best and only honest consistent method of giving an amplifier's power rating. Some manufacturers or dealers give very misleading power ratings in efforts to make their products appear more powerful than they really are. Like "peak power" "music power", "dynamic power", etc.
You would need to splice a little more length onto its main power lead due to the longer run required to the TJ's battery.
That would work but it'd be way overkill. Not to mention I don't like crimp-on splices like are in that kit, though they do work. There's some technique needed to use that kind of splice correctly so the wire doesn't pull out from an improper crimp and possibly short the power to ground.So I have never ran into a situation where I had to splice anything on my TJ.
What all would I need?
EDIT:
Would this work?
https://www.crutchfield.com/p_007CK12/Crutchfield-CK12.html
All you need is probably 10-12' of 12 gauge red wire, a crimp-on ring connector, and a friend who knows how to spice a wire by twisting the two pieces together and soldering them together which is easy. Heat shrink tubing should be placed over the splice, a couple layers wouldn't be a bad idea, to insulate it.
If you don't have a friend who knows how to solder, it's relatively easy with a few pieces of instruction which I can help you on if you decide to do it. Any hardware store will have a small inexpensive soldering iron or soldering gun and solder, and everything you'd need. Don't confuse soldering which is relatively easy with welding which takes considerable skill.
Surely a friend or a friend's dad knows how to splice a wire together?![]()
Don't let a two minute wire splice job that can be done at any auto stereo shop cheaply cause you to look at something else.That's one of the reasons why I was looking at the other 2 head units in the OP.
Yes. So my step-by-step instructions on how to solder & splice seemed too hard to do? I assure you that once learned, it will help you throughout the rest of your adult life. It's too easy to be afraid of trying it as described.Would this work to join the wires together?
https://www.crutchfield.com/p_669PP500/Posi-Products-Car-Stereo-Wiring-Harness-Connectors.html
Oh yea! Everyone walking around carrying their car stereo and pager... but way back in the day Sony when they had pull out outs
Oh yea! Everyone walking around carrying their car stereo and pager![]()
Or mail the wiring harness and wire to me and I'll splice it and send it back to you.
Every man with a Jeep needs to know how to solder, those of you who haven't mastered that relatively easy skill should learn it. Grab a soldering iron, rosin-core solder, and some wire. Strip the wires and practice a few times, you'll soon get it and see how easy it is. It's too easy to learn to be afraid of the process which is just a very basic skill like making your own breakfast in the morning.![]()
