Sorry....not TJ, it is KJ related.....but it's all the same-ish stuff so it shouldn't really matter. My 02 Liberty is my daily and the AC has been giving me fits. I'm hoping someone knows more about this stuff than me. Here goes...
Last summer my AC compressor went on me, a bearing or the clutch was making a racket. I replaced it and everything was fine last summer. I also replaced the low and high pressure lines along with the drier/accumulator at the same time. Installed new o-rings and gaskets too.
This spring the AC was cool....now it is just plain warm air. I figured I was low on freon so I took it to a shop to have them evacuate it and recharge it which they did. It passed the leak test and they filled it up to whatever it says on the sticker under the hood. No change.
I started poking under the hood last night and noticed a couple of things:
I really really don't want to put an evaporator in this. I've already changed the heater core before and it is an all day job. Thanks in advance!!!
- The low pressure line going from the Condenser to the drier/accumulator is ICE COLD. This makes me think the condenser is working.
- The AC compressor is short cycling. 5 seconds on, 5 seconds off or something roughly like that. Not sure if that is normal or not. Perhaps a restriction somewhere?
- I'll check tonight but I don't remember if the line from the drier/accumulator to the evaporator is cold or not. I think the drier/accumulator should be ice cold too right?
- Line coming out of the evaporator is warm/hot.
