Quote.
"Unless you dialed in the ride height to be the same with the correct amount of shock travel, then the issue is not spring rate related, it is ride height related.
Put another way. If you take a heavier rate spring and put it on a rig that is lighter with a shock that is set up for a specific lift height, then the balance is off. What will happen when you encounter higher level events is the rear end will kick up faster and hit the end of the shock which tries to lift the axle off the ground and that will seem very harsh in ride quality.
If you take the same exact set-up and put a softer rate spring in that lowers ride height and brings the shock travel back into balance, then the ride improvement is from the travel of the shock being utilized better and not from the softer spring.
I also find it very odd that we can swap a different rate spring in without making any other adjustments. I've yet to see springs with these different rates that didn't also produce a different ride height. What am I missing about these springs?"
