Ok you guys made your point. I suppose heat louvers on the hood is better than my current setup - no hood at all. You just have to understand my engine is so pretty right now, I don’t want anything on it, even those dirty little water droplets!!
i just got 1 from amazon was 103$ w/free shipping, it's the same .080 thickness GR claims.
i didn't want the spyder and GR was 40$ extra for shipping
it does not have a rivet option (unless you use big 1's), it comes with stainless hardware.
and powder coated black. unless the coating is crap i'm not seeing anything that would be reason to spend another 80$
https://www.amazon.com/gp/product/B07NL31QRS/?tag=wranglerorg-20
it does have some forward facing vents (those closest to the windscreen).
This may be the one mentioned that has studs already pressed in and doesn’t appear to be the cheapest option.
https://www.hylineoffroad.com/jeep_parts/jeep_tj_hood_louvers_tj_hood_louver_03_06
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=184390415654I had not heard of this. I like cheaper.
I'd like to put vents in my hood - but as it rains constantly here in Florida, I really want to minimize water run through. Buick style round ports on the sides of the hood would be great - can't find any decent ones though.
I think vents would help mine since the LS fills the under hood area. I am sure anything to creat more air flow would benefit the engine cooling. What I would like is some sort of side hood vents if anyone has suggestions. That way water is less likely to drain all over the motor.
That's where I'm at too - why I'm wanting Buick style ports.I think vents would help mine since the LS fills the under hood area. I am sure anything to creat more air flow would benefit the engine cooling. What I would like is some sort of side hood vents if anyone has suggestions. That way water is less likely to drain all over the motor.
Do you have an inside view?Another vote for the genright ones. I bought the 5-piece kit, but only installed 3. Takes a little more work than a 1-piece one, but I like the look better.
See post #29Another thing I did not know I needed! This one has been linked already in this thread.
