finally, nice enough weather to get started on the dpg lift kit. jks 1.25 inch body lift and 1 inch mml to start with. the body mount instructions include this step 5...
5. MODIFY RADIATOR
Locate the four fan shroud mounting holes on the radiator.Measure exactly 1” below the factory mounting holes and mark the location with a center punch. NOTICE: The lower passenger side hole will line up with an existing factory hole and will not require marking with a center punch. Drill a new 1/4” hole through the three center punched marks.
i don't understand why the shroud needs to be lowered since the motor (and fan) is lifting. the body mount instructions do have optional paths when the mml is included, but step 5 remains regardless..
thanks for any thoughts.
5. MODIFY RADIATOR
