I started off thinking I'd done something stupid when I couldn't find the carrier bearing that I'd pilled off the ARB. So I'd given up looking for it and was just going to use the new bearings instead. Then I opened up the box with the gear install kit and there was the old bearing.
So I spent the next hour or two making setup bearings for the CRD60. Setup bearings can be bought or made. If you are installing new bearings into your axle and the bearings are good then you can take flap disc and turn them into setup bearings.
80 grit and & dremmel works wonders. You want to take off just enough that the bearing will slide onto and off the carrier & pinion gear with a small tug.
It takes a few OK more than a few test fits until you get just enough off.
Slides on with a little push.
And then slides back off with a small tug.
So now I have setup bearings for a Dana 30 & Dana 44 and now a Dana 60.
Then I cleaned up the shims so I can measure them so I have a starting point when installing the new gears.
I'll have to say this is a rather large shim stack and am not sure why those old gears took so much to setup. We'll have to see what these new gears take.
Before I can start to setup the new gears I've got to get the load bolt installed but as with everything on this rig it's never easy. If it was a standard Dana 60 Carl already has the measurements for how deep the load bolt needs to be installed. But it's not a standard Dana 60 so I have to follow his video and find out the depth that it need to be at.
I was cleaning the inside of the housing and I think I found a lot of the pieces of the broken pinion teeth.
So I flushed the housing 3 times with brake clean until the rag came out clean. I'll get started on the load bolt layout tomorrow.
