So I’ve been having some issues with my winch, a Quadratec 10k winch with synthetic line. I’ve had it a few years and have only used it a handful of times. Anyways, I went to let out some of the line, not under any load and I get the clicking of the solenoid but the doesn’t go in/out.
Initially I had it wired with an Inline fuse, looking back I probably didn’t need that. I thought it may have been that so I got another fuse and then took everything out and wired it straight to the battery. Still nothing.
Looked up a video on “jumping” the winch with cables from the battery straight to the terminals on the motor and nothing, no spark with I saw in the videos. Checked with test light and it was reading 12v. (Also hooked up straight to battery booster, no go)
I then hooked up the jumpers to the solenoid and activated the switch and found that the motor was getting power from the solenoid at the motor
I’m no electrical/winch expert but I’m thinking the motor is shot? Super disappointing considering I’ve only used it a few times. I know you get what you pay for but I can’t justify spending a ton when I barely go off-road.
I tried getting the motor off but one of the Phillips head screws in there is nearly stripped, tho manipulating the motor around a lot of crap Maybe dirt or rust flakes were coming out... winch definitely hasn’t been submerged or anything.
Quadratec does offer a replacement motor for $100 but I just want to be sure that’s the issue before dumping more money. Any input would be appreciated.
edit: battery is new, no issues with it.
