That is a self recovery winch, not a rescue winch. They can use their own.cranking that handle long enough to pull out 2 or 3 stuck jeeps
That is what millennials were bred for...That is a self recovery winch, not a rescue winch. They can use their own.
Me I would use poly rope. And a factor prolink. I love mine. Not much room for eror.
How does the forum feel about a Warn Zeon 12 w/Steel lines. Found on CL for $800, looks like it was mounted but only for show.
Most high capacity winches use higher gear ratios to pull those loads meaning they tend to be slower. 216:1 vs 162:1 for the 12 vs the 8 Zeon for example. About 3 min vs 4:30 min to spool the whole thing, something to consider. Personally I picked a 10K winch because it was a bit slower and draws a bit less current than the same winch rated 8K. I felt slow was an asset for me. The only physical difference was the gear ratio on mine and I have a feeling the Warn is probably similar.How does the forum feel about a Warn Zeon 12 w/Steel lines. Found on CL for $800, looks like it was mounted but only for show.
How fast can it pull at 10K?My 8274 can do 8K pull at 75' per minute, that is the standard to compare it to.
Well do you want a deal or an awesome project? The 8274 is friggin awesome for a winch. The Brits have these things hands down. Google Gigglepin...2 7.5 horsepower motors mounted on a top plate. Mega solenoids and good batteries to make these things work. Also having the motor and gears external from the spool allows the winch run cooler. Cooler=more efficient on long or multiple pulls.Well, all good to know and I've learned something new today. I have a shittybilt 9500 and saw the warn, seemed like a good deal. I'm not in the market, just looking for deals.
Holy crap....those things are insane. I don't even know what to say about those things, way out of my "want to know" thing, but they are super interesting.Gigglepin...2 7.5 horsepower motors mounted on a top plate
