Solid Axle version of the 5.5" kit
Ram 1500 brakes on a Spydertrax knuckle.
Custom dual piston big brake kit to get rid of the Chevy D-52 calipers on the Reid conversion knuckles for the TJ Inner C.
Reid Dana 60 knuckle big brake kit.
F-450 kit we do with Yukon hardcore hub locks
And my own custom kit for my personal rig.
I have more if needs be.
Makes me wanna ship my hubs 'n stuff to your shop for a perfect install.
Playing with the hub lock with the tire off of the ground so you can turn the tire and watch how the hub lock reacts when it engages the locking clutches to snap into place will most certainly answer your question.
I'm am by no means an expert. I have however been running hub conversions since 1999 and I have installed at least 50 of them for folks and adapted my big brake kits to another 75 or so. In fact, I just finished up adapting a 5.5 version to a WJ knuckle using an 02 Explorer rotor, WJ calipers, machining down the hub flange, and having that drilled for 1/2-20 threads. All to make that fit inside a 15" Alcoa rim.
I also install and set up the Yukon hardcore kits in the F-450 hubs where we have to accurately measure and build spacers to control the unlock side since they operate in reverse of the typical Warn hub locks.
So no, not an expert, but I may know a thing or two so you should go try my suggestion and stop being such a miserable twat.
Well, you really missed assumption that one by a mile.
Doubt he’ll be old around here.
Only as old as you feel, aches and pains not included, but I'm 71 thank you and it's been 53 years since I owned my last jeep and still do all my own wrenching. I'm just not a rock crawler like you young bucks.
I should have had you do that to mine years ago. Yes I know you offered years ago lol.This comes up quite often in discussions with owners of hub kits. There is a very limited selection of press in studs to get more thread length past the flange face. The easy way to solve that is to just clock over between the old pattern with a new one and drill the rotors for 1/2" clearance holes, then drill and tap the hub flange for 1/2-20. You can go all the up to a 3" long screw in stud that way. Never a problem with too short studs after that. And, it is something we do all the time.
Yes, I can be a miserable OLD twat at times and jump to conclusions but all I wanted to know if was a simple yes or no answer so I could forget it later while having a, as one of the others said, having a Biden moment. I know how it engages and disengages but it has been 53 years since owning my CJ and if I recall correctly there was a more positive stop at both positions not free like this Yukon. Yes I have reidentified myself after my dog since I'd rather not be a "Gym Sock". I apologize and you do have some impressive credentials, have a nice day!
Yes I did, quite impressive.
If you are running the 5.5" Yukon Hardcore hub locks, they operate backwards of most of the stuff out there in common use. They default locked so when you turn the lock knob to unlock, you are pushing the two clutches apart manually. If there is any side to side bind in the front axle, they can be very difficult to unlock. When you turn the knob to the lock position, you are relaxing the force the ramps on the lock knob used to force them apart. Then the spring pushes the inner clutch outward to engage the two sets of teeth. If the teeth are not lined up, nothing will snap into place until they line up by turning one side more than the other. That's why you have to jack up one side and see how it all works.
The old Warn and similar style have detents in the lock knob to stop it at both positions. They work conventionally in that when you turn the knob to the lock position, the screw ramps compress a spring that then attempts for force the clutch halves together. They use inner and outer splines on those and when the splines line up, it locks in.
Yukon operates more like a locker does with opposing faces of teeth that lock together.
