Exhaust Manifold Replacement Walk-Through?
I just did mine today...took about 4 hours...was fairly painless and that's saying a lot for this Jeep...took a month to change the clutch with some stuck bolts. I'm just estatic I took something apart and put it all back together in the same day... didn't break anything or need to run to town for parts. Used the Banks torque tubes.
Nice work! Any lessons learned in the process?
15 mm ratcheting wrench is going to be your best friend. Some of the bolts are not really visible...so your on your back (unless you have a lift) fishing bolts with tips of fingers with your arms fully extended. Torque wrench doesn't fit on anything. Clean surfaces and then clean em again. Might as well do your valve cover gasket while it's accessible. Was thinking about making a video since most of them on YouTube don't cover the extreme bolt fishing. And antiseize!
This is really great, thank you. Going to read this alongside the FSM before I tackle the job.
Are you happy with the manifold you chose?
Yeah. I am sure it will crack like all the others, but for the price and the fit, I would definitely purchase it again.
This is a very easy procedure on our engines, so even if it lasts only 2-3 years, ill be happy. to be honest, I kind of look forward to swapping it out again. The 4.0 owners have it much worse.
Hey @macleanflood and @SvtLdr, is it a 14mm or 15mm flex socket that I'll need? One of you said one and the other said the other.
I know, I should just go check the FSM or get under my Jeep, but I'm doing my homework from the office between calls. :-)
I know, I should just go check the FSM or get under my Jeep, but I'm doing my homework from the office between calls. :)
It appears that the tapped holes in the cylinder head are 3/8"-16. You could use a 9/16" or a 14mm socket on the bolts. For some reason a 14mm fit better for me so that's what I ended up buying part way thru the project.
Reactions: SSTJ
And my 97 it was all 15mm heads. Should have replaced the hardware but didn't.
All I needed was a racheting box wrench.
Either I don't have the original bolts or I didn't bother trying a SAE.
Reactions: SSTJ
SSTJ,
If I’m not mistaken, we both have the 2.5l. I’ve replaced my exhaust manifold several times now. It’s a little intimidating to get started, but once you do it, it’s easy peasy. No need to remove a fender. Just get in there and do if. I like to put painters tape on all the electrical connections and label each one so that I know where to connect it back. It’s not that bad. A mechanic friend even showed me how a wiring harness will have “muscle memory” in the sense that if you shake it out into place, it will lay down as it used to be, like it remembers it’s position.
Oh yeah, when you pull the fuel rail, be sure to keep up with all the o-rings. Some people say to change them. I never have. Just a little lube to slide them back in.
Reactions: SSTJ
@SSTJ, I overlooked the fact that you're working on a 2.5L. My experience has only been with the 4.0L.
Reactions: SSTJ
Looks like @Stox5225 also has the 2.5L like I do. Any pro tips to share from when you installed that Banks manifold?
