DIY Rear Storage System
Great build, honestly. And the fact you still have so much open space to place things you can easily access from the back of the jeep, and stuff the small cubbys and gaps around the wheel wells. Looks great man good job! Imagine removing the passenger side and incorporating all that space lol.
The past 4-5 weeks of lockdown I've been working on a little project in my spare time. Wasn't too keen on any of the rear storage systems on the market so I figured I would make one myself. This isn't exactly a build thread but I figured I might as well post up some pics i took throughout building it to show you guys how I did it in case anyone wants to build something similar or take some inspiration from it.
I used AA grade 12mm marine ply for the whole thing so it's waterproof and the whole thing is super strong.
So I started with the base. I used some countersunk m8 bolts to bolt it into the rear seat mounts holes.
I cut up these pieces to mock up the main part of the system and check that it all fits.
Screwed these parts together. Because the screws were being screwed into the end of the ply I drilled pilot holes and had to be very careful not to split or bulge the ply but it ended up super strong. The halves are divided up so that my little fridge will fit on the left and I can make a drawer for the right.
It took ages to get it just right but I cut the hole for the fridge so it would fit perfectly snug to stop it rattling around.
Then I put these little dividers and edges on just to help with organisation and things falling off or into the fridge.
This was the first test fit. To put it in you gotta take the roof off and slide it in sideways which is a bit of a pain for all the test fitting but fine because I plan on having it in 99% of the time. It fit perfectly, nice and tight that is probably doesn't even need those bolts to hold it down but better safe than sorry.
Another tight fit but my swag just fits in where I intended (A swag is a 1 person tent sorta thing for you yanks).
So I got the drawer made up next. To save space I used this this nylon plastic for the drawer to run on instead of traditional drawer slides. It slides nice and smoothly and even saved me some money too.
Used some wood filler to cover up the screws and ready it for paint.
I used a black exterior paint to make sure it's tough and durable enough for the inevitable abuse. I originally tried to rattle can it but it just looked crap so I cracked the brush and tin out.
Once the paint was dry I cut some rubber backed marine carpet to shape and carpeted the top faces, the back face and inside the drawer.
View attachment 164099View attachment 164100
Here's a rough idea of how the top areas are going to be used to store water, fuel, air compressor and recovery kit.
I used these D rings to secure all the cargo loaded on the top. They're plenty strong enough but they rattled pretty bad so I took them apart and put some duck tape around the D ring so they fit snug into the mounts and don't rattle at all.
You can see a bit better the rest of the tie downs I put on the top, and also the mounts I used to mount my axe behind my drivers seat. They're called quick fists and can be found on ebay.
Here's the final installation. Pretty stoked with how it looks and fits and all.
View attachment 164105\
You can see I've lined the inside of the drawer with the same rubber backed marine carpet as on the top and back so all my food stuff doesn't rattle around in there too much. If you look close you can also just see the magnetic latch I've used to stop the drawer rattling open on the trails. It's a heavy duty 10kg pull strength magnetic cabinet latch and it does the job well.
Easy access to my axe and whatever cargo is on top through my drivers side.
And plenty of space to access the fridge on the passenger side.
And lastly a pic just to show how it doesn't interfere with the driver position at all, both seats can be moved as far back as before.
So that's it, hope everyone enjoyed my little project and maybe even got some ideas for their own Jeep.
very cool
Reactions: Hammer24
thanks mate, yeah you could get a lot more room with that seat out but 2 seats is already not enough to be honest lol
How do you power the fridge, is it hooked up to your main battery?
it's hooked up to a secondary battery which is a deep cycle lead acid battery, i think 80ah from memory, that can also double as a spare starter battery. Very common here in aus to have a dual or even triple battery set up as camping is generally very remote so you need to be able to power fridges (usually a lot bigger than mine) and all that for long periods. It charges off the main battery but is connected via an isolator to avoid running the starter battery flat
Nice job with this. How has it held up since you built it? Any modifications?
The item you have rolled up against the tailgate is a tent? That's HUGE. That's about the size of a party tent.
Thanks, its held up real well actually. The only thing i've done to it is carpet the whole thing as the paint wasnt holding up as well as i would've liked. I actually much prefer it this way anyway and it's much harder wearing. Here's a newer pic;
Also its not exactly a tent, its a swag - an australian one man tent sort of thing, have a google and look at some. they dont really make sense on paper because they're huge when they're packed up and tiny when they're set up - but they really comfy, stay dry inside real well and super easy and quick to set up and take down, especially as I leave my pillow and sleeping bag in it when I roll it up, and it has a thick mattress in it and with my particular type theres no need for pegs or anything. perfect for when you're on a trip and relocating every day.
Reactions: matkal
Carpet looks great.
I am a long distance hiker. My entire sleep system (tarp, hammock, quilts, suspension, straps, pillow) fit in a fraction of my backpack. When camping with the TJ, I tie off to one tree at one end of the hammock, and the TJs roll bar on the other. Best night sleep ever...far better than my bed at home, weighs just under three pounds and takes up no room. I can't get my head around a one man shelter that stows that large even with the other stuff rolled inside. Not judging it.. what's important is that you are comfortable. But with storage as challenging as it is with the TJ, dedicating that much space to shelter... To each his own.
Great job on the storage none the less!
Reactions: nathanotis
Carpet looks great.
Before I went camping with someone who had one I thought they were a stupid piece of equipment too as they take up so much space, but it's just so convenient as it takes about a minute to set up and the same to pack up which makes it ideal for moving camp every day and getting into camp in the dark. Also no need for trees which aren't always around, or pegs which sometimes the ground doesn't work with. Not to mention it stays super warm and they're as comfy as any bed I've slept in, much better than a tent with one of those thin camping mattresses. I tend to pack very light when I'm camping anyway so the size isn't that much of an issue anyway - i manage to fit everything I need for a week off the grid quite easily, although seeing how much stuff some people pack I can see why the size would be an issue
Thanks, its held up real well actually. The only thing i've done to it is carpet the whole thing as the paint wasnt holding up as well as i would've liked. I actually much prefer it this way anyway and it's much harder wearing. Here's a newer pic;View attachment 293727
Can you link to the swag tent you have? Google turns up a few different styles.
Reactions: Wtrask and matkal
A really neat solution, I think that I will make a modified version (I keep my spare on the floor, rather than hanging off the door), thanks for sharing.
Certainly can see some advantages to it.
Not trying to convert you but if you haven't slept in a proper hammock, you'll be surprised how comfortable it is. In any event, the storage system is cool as all get out. I haven't committed to going without a rear seat yet...
I have a proper hammock, i've actually used it inside the TJ before. i like it but i prefer to sleep on my front so it's not ideal for me
Great storage set up. I’m thinking of doing a similar thing in my Jeep but with a sleeping platform for late season moose hunting and salmon fishing in Maine. I do a couple backpacking trips a year And I can say I am not a hammock sleeper. It takes a special breed for that! I move around way too much!
