How bad is it to drive without a steering stabilizer?
Asking for a friend…
You could drive safely forever without a steering stabilizer. Its more accurate name is a steering damper and its job is to isolate/protect the steering system from shock and impact from hitting bumps/dips in the road. Its real job is not to stabilize the steering.Indeed I have noticed no difference. I think I lost the washer within the day today but cannot recall the exact time. I was off road most of the time.
I have a 4h highway drive to get home though and my question is, should I adjust my driving as having no starring stabiliser may be dangerous?
Let me know as I'm a bot worried... Thanks!
Can I recommend a zip-tie to fix that for you?
Thank you! @Jerry Bransford Indeed I have noticed no diffuse so far driven the Jeep for 30ish miles on road after diagnosing that this happen. Any thought on why it happen? Loose washer or wrong lighting of it?You could drive safely forever without a steering stabilizer. Its more accurate name is a steering damper and its job is to isolate/protect the steering system from shock and impact from hitting bumps/dips in the road. Its real job is not to stabilize the steering.
Your photo isn't close enough or from the right angle to know if the bolt snapped or if the nut simply came loose and fell off. You just either need to replace the nut or replace the tapered stud and nut.Thank you! @Jerry Bransford Any thought on why it happen? Loose washer or wrong lighting of it?
I have not run a stabilizer in ten plus years.
Well that's comforting. I was a afraid to drive on the highway and that was my main reason of posting this tread.
A damper isn't necessary to steer, but having one makes driving much nicer.Shouldn’t need one
