Here's what I know. The Jeep has been sitting since December 24th, when it was parked due to a water pump failure. After replacing the water pump, belt, and fan clutch, I tried to start it but the battery was weak and almost dead. I tried to jump start it from another vehicle but it wouldn't start. I charged my battery and it still wouldn't start. The engine starter cranks and the engine spins but won't start. The fuel pump turns on and builds fuel pressure when the key is turned on. I pulled the air intake off the throttle body to spray some starting fluid and it smelled like gas. The starting fluid did not help it start. I pulled the spark plugs today to check them out and I see no red flags. They have a heavy gas smell.
I'm not sure where to go from here. Any help is appreciated!
