Hunting, rational thought, a new rifle
StG58
TJ Guru
On the road.
I hunt with a rifle that tips the scales at about 14 pounds, loaded. It's a monstrous beast, but I've liked it and packed it all over the wet side of Oregon. Rain, snow, sun, sitting on a ridge, sneaking through the creek bottom pucker brush. I've got a bunch of different loads for it. Shotgun loads to target loads to Grizzly loads. It has always gone bang when I pull the trigger, and I've always hit what I aim at with it. (Unless I mess the shot up)
Scouting Elk this year the beasties are way further back and in much thicker cover than ever before. I'm older too, and not as strong as I used to be. That got me to looking at a lighter and more compact rifle to tote through the woods. Something that fits in the TJ without drama. Made of stainless steel so I can keep ahead of corrosion a little easier. Something with a little interest to it.
I have hunted pretty much everything in Oregon with a pistol at one time or another, which got me to thinking of a pistol caliber lever gun. Chambered in 44 Remington Magnum or 45 Colt. Decided on 45 Colt. Did you know you can load a 45 Colt to 44 Mag levels in the right pistol and with much less drama as well as heavier bullets? Works really well, just as an aside.
So anyway, Started looking around and found a very strong Model 92 Carbine style lever gun that seemed to fit the bill exactly. Decided to do a little research before I popped for the thing, and this is where the point of the story comes in.
Started asking around about hunting Elk in the Oregon jungle with heavy bullets, a 45 Colt and a lever action carbine. The same exact people who swore up and down that the 45 Colt was the best thing since sliced bread for hunting Elk with a handgun, were telling me that a 45 carbine would never do. Same with the 44 Mag. I was regaled with many stories of how many big Roosevelt Elk were cleanly taken with various makes and models of revolver in both those calibers. How hunting with a 45 revolver (or 44) was sporting and the way to go. Etc, etc. Ask those same people if a nice carbine in one of those calibers would cleanly take an Elk, and the story would flip. On no! Never! Stupid! Inhumane! Bunches of technical sounding explanations followed when they were pressed on the matter. Elmer Keith would never approve!
To make a long story even longer... The technical details of the matter are: A lever action carbine with it's longer barrel will give about 300 fps more velocity than the same exact load in a revolver. The longer sight radius makes aiming easier and more precise. In a pinch, you can shoot the same load out of your revolver and your carbine. (technically, they take different loads for best results, but you can do it if you need to) Pistol caliber cartridges use less powder, but more lead to do the same thing that a rifle cartridge does. If it will shoot all the way through an Elk from almost any direction, how much more do you need? I just called BS on all the naysayers and made up my own mind.
The new stainless lever carbine in 45 Colt is on it's way, though it won't be ready for this Elk season. I guess that I'll just have to use my Ruger Super Blackhawk this year. :)
Considering how many (thousands upon thousands, at least) deer, elk, bear, etc, have been taken with .44-40 lever guns since the 1870's (although I must admit that the .30-30 has taken far more), I would have to believe that a 44/45 range pistol round in a similar rifle would be more than effective, assuming reasonable ranges and good bullet placement. Yeah, you're only going to get about half (maybe 2/3rds) the velocity with a pistol round, but you're chucking a whole lot more mass downrange, and that does make a difference. With modern lever guns having better steel and stronger construction, and throwing in better powder/bullet combos and the ability to load pistol rounds a bit hotter for a rifle, you end up with a really good short-mid range brush gun. Have at it, says I!
Reactions: Head Lice and StG58
It's funny that you bring up the 30-30. That round has put more meat on the table out of a lever gun than almost any other two rifle / crtridge combinations combined. Almost no one hunts Elk with a 30-30 any longer. But a few decades ago it was the "go-to" truck / scabbard rifle out west. My how things have changed. The critters must be tougher now and our forebears must have been made of sterner stuff than us. :risas3:
I looked at the 44-40 as well, but it's not so popular today. Hard to get good strong firearms in that caliber, and that thin neck makes for interesting reloading. Nice, accurate cartridge though, and often overlooked as a general purpose round.
Reactions: MikeM
For shorter ranges it should be fine. Elk are large, tough sob's that can take multiple hits and keep on trucking into the next county. Stick with heavy, hard cast flat nosed bullets loaded as heavy as you can. The 45 LC can be loaded to crazy levels when done correctly.
14lbs?? What the hell you shooting? My long range, fat barreled comp gun weighed about 17.
Reactions: StG58
Exactly! I'm loving my 45 Colt revolver and how versatile it is, and how easy it is to load up a good cast load for it.
My current and favorite rifle is CZ 550 American Safari in 458 Win Mag. 24" barrel. 2x6, 30mm scope. American Walnut stock. Elk and deer hunting are slowly eating it alive though. It was never built for the rain and snot of hunting in the coast range. Funny thing, my paper patched 405 grain cast loads give me groups that are half the size of the factory target. Probably at higher velocity as well. It's a rifle you don't want to load to the upper end of things. Recoil goes from pussycat to fierce rather quickly.
I should take delivery of my new 450 Bushmaster hunting rifle in the next week or so. Not sure how it compares to a 44 of, but it's a pretty stout load. 2200 ft pounds or so at the muzzle.
Why am I using a 450 BM? Well, for some reason, the state of Michigan drew an arbitrary line across the state and south of that line, necked down rifle cartridges are illegal to hunt deer with. You can hunt coyote with a 223, wild pigs with a 30-06, etc, but big game is shot gun, muzzle loader only...or straight wall rifle cartridge. 44 lc would qualify as well. I didn't want to hunt with a lever though. My new 450 is based on the AR platform...pretty bad ass gun. Mine will be similar, but gray instead of od green
Reactions: Hunter Rich and JMT
Interesting thread ......
Also living on the 'wet side' of the Coast range, and as you've alluded to ..... it does get wet. Very wet!
Fourteen pounds is a heavy musket .... and elk of any sub-species can take some hammering ..... sometimes.
Am getting older and using my Winchester M70 'Featherweight' (30-06 Springfield) more and more. Topped with an American made 6x Leupold compact scope. Have used it on Black bear, Black-tailed deer, Canada moose, and Mule deer. In Grizzly bear country .... I use a heavier musket.
Keep us up to date on your new purchase ...... have fun.
Happy trails to you ......
Reactions: StG58
When I hunt Michigan whitetail, I use a Remington model 7 in a 308 caliber. The gun and scope come in around 8 pounds. Can walk for miles (which I do) without being too uncomfortable. I couldn’t imagine using a 14 pounder all day. Especially in some of the hill country where elk are located. I have to contend with snow some seasons but that’s about as bad as it gets. The hills are mild compared to anything you experience. Good luck, I wish you a safe and successful season.
Reactions: StG58
I’m in Central and South TX. Our game are white tail and axis and we shoot hogs, coyote and bobcat when we can. I used to use a .308 bull barrel Remington 700 and a .270 Remington 700. I realized I didn’t really need that heavy a load for the game. I opted for a Tikka T3 Lite in .223 with a Vortex Viper PST 4-16x. The scope is worth its weight in gold. FFP Mil-Rad that tracks with excellent precision. I strive for perfect shot placement with the 62gr Winchester fusion rounds. It’s really all I need and scope and all weighs in at 8.4lbs. The action is so smooth on this thing it literally puts the Remington 700 action to shame.
Reactions: Mike_H and StG58
I have Marlin lever action 44. Used for years on Big Boar's when hunting with my dogs. I would carry my hand gun for up close and personal shots, but if they were out a ways for my hand gun, I would use my lever Marlin for a better shot. With a 240 gr bullet it would put those big tough Boar's down right now. Love that rifle!
Reactions: StG58
Agree, the Tikkas are very nice. I have two T3's, in 7-08 and 7 mag, and the actions are as smooth or smoother than my professionally worked 700 action. I threw together a load for the 08 straight from the Barnes website and shot .6 for 5 shots at 100. Best load with lots of work from my custom 700 was about .3 for same shot and distance. The Tikkas can shoot for sure.
Reactions: JMT and StG58
Chip shot for the big Weatherby. Pretty sure it put a hurtin on a CA blackie :D
It is....as I was setting up, he was walking closer....He first started out at 565 yards and I wanted to shoot him there. My wife had the same rifle and killed her Blacktail at 502 yards. I wanted him to stay at least 503 yards out. :-)
Reactions: UpperMI and Rob5589
Love hearing and seeing what-all everyone is hunting with. It's an interesting conversation. My 45 Redhawk will put 270 grain semi-wad cutter out the muzzle at 1,300 fps over the chrony. Figure about 1,600 for the same load out of the longer barreled carbine. 150 yards is a long shot around here. Most are 80 - 100 yards. You're lucky to see 100 yards with the terrain and brush where the Elk hang out. Just made sense to go with a carbine.
I load the wife's #3 Ruger, 45-70, with 350 grain lead rnfp's. They go about 1,400 fps, and we've never recovered a bullet. Two 3/4" holes, one on each side. If an Elk takes off after being shot, you can loose them pretty easy. That's hours to days to find them. Just gotta keep them from running very far, so it's blood loss or getting a central nervous system shot. Two big holes seems to be more reliable.
My buddies think I'm crazy, stupid, or both for hunting that area. Can't argue with that. It is home though.
Reactions: Rob5589
When I was sighting the Weatherby in, I was shooting a 6" group at 1,000 yards. Now already to take game a long ways out and they are all close now! Before getting that rifle I saw game too far out to shoot. Oh well.....still putting meat in the freezer and that's all that counts.
Reactions: Rob5589 and StG58
Where in the heck did you come up with a Ma Deuce!? ...and how did you talk your wife into shooting it?
That's just too cool. At what, $5+ a trigger pull?
When my wife isn't shooting her Weatherby....this is the other long range gun she likes to shoot. I try not to make her mad at me.
I bet that thing kicks like a mule and bites like a crocodile! Nicely bracing tripod! You guys are serious. What do you shoot with that thing, elephants? Maybe some of those crazy worms from Tremors? Remember this scene
