Looking for pictures of metalcloak overline fenders on a Jeep with 33” tires and 4” of lift, I’ve looked and looked and can’t find many
Ooh ooh, faux winches!those are all flied in the mods with no benefits category along with angry bird grills, beetle eyelashes and the new faux winches.![]()
ay........if you tee it up somebody's gonna take a swing, even if it is a potato.You should of filed you comment there also, I forget most guys here are comedians
Wrong guy, I am only on this forumay........if you tee it up somebody's gonna take a swing, even if it is a potato.
if you like the look of those fenders go for them. but most here try and help forum members avoid gimmicks.
am i correct that i remember you from the other Jeep forum? if so welcome over, this site has more info IMO.
right down below are links to similar threads....some have the pics you are looking for.
You have any side shots? I’m curious on the rear wheel clearance with that setup.
This is the closest one I have. I can snap a pic when I get home. The only thing is, I have not cut the body to match the rear fender. Didn't have the tool at the time.You have any side shots? I’m curious on the rear wheel clearance with that setup.
I don't love the look, but even if I did I think 33s will be way too small for that look with 4" lift. Same is true for proper high lines.
Fully agree,I think mine has too much tire gap with the lift I have and the fenders. Only reason I have them is I got an amazing deal used off marketplace after I had my lift already.I don't love the look, but even if I did I think 33s will be way too small for that look with 4" lift. Same is true for proper high lines.
Agreed, mine with highlines and 35s is just on the lower edge of what I'd accept. 37s on an LJ is an eventuality I think.I agree, 33's would be too small. A true 4" 35's IMO would look small but would be better than 33's. At 4", personally I'd be looking at 37's if I had the axles and gears to handle them.
