Finally got around to doing a tire clearance test between stock fenders and metalcloak overlines. The axle, suspension, control arms, and steering are all stock. The tires are 33x12.5 on a 15x8 rim with 4" BS. There is a 3/4" body lift so keep that in mind when comparing the clearances.
The tire when straight hits the stock fender with 3/4" of bump stop gap. Keep in mind that without the 3/4" body lift the bump stop gap would be at least an inch or more.
When turning to the left the tire drops slightly due to the caster angle but still contacts the rear of the wheel well before the steer stop is reached. To turn to the right the axle must be lowered 3/4" to clear the fender lip, so the bump stop gap is now 1.5".
With the metalcloak overline fender, the tire still has 1/2" of clearance with the bump stop resting on the contact pad so the axle is fully articulated. Keep in mind there is a 3/4" body lift, so without the BL there would be some tire contact at full stuff.
When turning to the left, there is still tire contact before the steer stops are reached, but a slight bit more steering angle is achieved. When tuning to the right there are no issues what so ever, and the tire does not need to be dropped for clearance. The axle is still in contact with the bump stop. Again, keep in mind the extra 3/4" clearance from the BL. A small spring spacer or some 1" H&R springs might help with the rear wheel well clearances when turning left.
The overline has a 6" flare, and there is no contact with the flare when the tire is either straight or turned left/right.
And as a bonus, here is the rear 33" tire on a stock axle, arms, and suspension compressed to the bump stop with 1/2" clearance all around the wheel well.
Everyone can come to their own conclusions based on the results of this test.
