^ that question was supposed to be for this guy didn’t know how to fix it though.
Good. I like a bit of rake.
I’d probably go with the OME light duty springs in the rear, unless you are planning to add a heavy rear bumper, larger spare, heavy loads for camping or over landing. In that case I might go with the heavy duty and leave out the 10mm spacer. You can always nuance things later, add a spacer here, subtract a spacer there. That’s what spacers are for. Typically, due to the 1” rake, a 3”/2” combo would get you close. But the real answers come by knowing your sprung and unsprung weight. That’s more difficult, but the real solution.What springs would you use on a stock tj 4.0 with a soft top? I want it to be level as possible
so just go heavies in the front and light in the back? And thanks for the reply.I’d probably go with the OME light duty springs in the rear, unless you are planning to add a heavy rear bumper, larger spare, heavy loads for camping or over landing. In that case I might go with the heavy duty and leave out the 10mm spacer. You can always nuance things later, add a spacer here, subtract a spacer there. That’s what spacers are for. Typically, due to the 1” rake, a 3”/2” combo would get you close. But the real answers come by knowing your sprung and unsprung weight. That’s more difficult, but the real solution.
Do you have a winch and aftermarket steel bumper in the front? The more weight you put up there the less lift you get. There is also a relationship be how much lift you have in the rear (ie the rake). Trying to get it exactly like you want it the first time without knowing and understanding a lot is unlikely.so just go heavies in the front and light in the back? And thanks for the reply.
No my tj is stock and I don’t plan on adding anything else to it.Do you have a winch and aftermarket steel bumper in the front? The more weight you put up there the less lift you get. There is also a relationship be how much lift you have in the rear (ie the rake). Trying to get it exactly like you want it the first time without knowing and understanding a lot is unlikely.
That said, A lot of people have been happy with 2933/2941 combo. I’d get the front 10mm spacers and if you need them, you need them. If not, send them back.
Famous last words...No my tj is stock and I don’t plan on adding anything else to it.
I knowFamous last words...
Try 2933/2941
The shocks control ride quality, springs are pretty much irrelevantI know. I just hope those 2933s doesn’t make the ride harsh or anything but I’ll give it a shot when I order my lift.
The 2932 and 2933 front springs have the same spring rate. The 2933 is just slightly taller probably to have the same lift height with more weight up front. They make a heavier rated front spring for those with a lot of weight up front and/or wilder faster driving style. IIRC the rears have 3 different spring rates. The 2933/2941 combo probably levels out stance so there is no rake.
After market bumper and winch. OME offers the same spring in both light load and heavy load, same size.
.... They make a heavier rated front spring for those with a lot of weight up front and/or wilder faster driving style. ...
