Can I drive with a broken 02 sensor bank 1 sensor 1? I know it can start right up but will it stall randomly or something going down the road?
This is the backstory if anyone is interested....
I stripped my 02 sensor bank 1 sensor 1 on my 06'. It is probably the hardest to reach out of all 4. When I changed my 02 sensors on my bank 2 all I did was spray with kroil for a few days, started up the jeep and they came right out. This bank 1 sensor 1 is incredibly awkward to reach. Normally I avoid using crescent wrenches or crowfoots in a situation where I can risk stripping a nut. But in this case a long socket wouldn't go on the sensor even after I cut the wire, there's no room. I haven't had good luck using my 02 sensor socket for removal, it has been very helpful for install though. I can't even remember the last time I stripped a nut or bolt that wasn't a torx head. But because it was in the ass crack of the engine bay I thought I was turning the 02 sensor when I was actually just turning my wrenches around the hex and stripping it. I might still be able to get a grip out of the hex but this is very frustrating. The only solution I can think of is cutting the 02 sensor off with a dremel which is taking forever, and then with the additional access maybe just maybe I can fit a regular 1/2 inch drive 22mm/7/8ths long socket. Failing that I will have to pay someone to weld a nut on there (I would think a stick electrode would reach up fine), and probably get charged a heavy amount due to the awkward location.
