Need low profile taillights and Savvy has no ETA in sight
Yep next set of tires I buy after the Mickey’s run out will be maxis
I’ve sliced two of them, but what I sliced the last one on, I’m pretty sure any radial tire would have been a goner. Are you running the Baja Boss?
I will mention one of my taillights started to have an issue with the running taillight part, the turn signal and brake still worked. I had a brand new taillight in my hand 2 days later.
Oh ya love your tj by the way,you didn’t have to drill a big hole?
Nope. No hole drilled. It uses the factory 2 bolt holes, then you just splice in the wires. They were pretty simple.
Mtz they are great in the mud
Reactions: TRE3TOP
Reactions: RINC
Why do that when you can get a single round light that accomplishes all of the above?
Must be an overland thing.
I was thinking about the warrior 2 hole,the only rust on the Jeep is a spot below the license plate holder.when they start rusting, armor 😂the savvy lights and the relocation bracket would cover it up also
  • USA Proud
Reactions: Apparition
If you need corner armor there is only one option. And it doesn’t include dual round lights.
Need low profile tails for overlanding,savvy has know idea when they will have them,they just told me it will be a long time,anyone have any other options,thanks
We're you able to get a hold of someone?? How? I want to cancel my tail light order. Ridiculous, no email or phone replies. Like seriously they're going to make me change my cc number to buy different tail lights?
Can a spacer on the gas can holder solve the problem? Just trying to look at alternatives.
I'm more confused about if worried about taillight clearance, how is the gas can not going to block the light from other drivers vision?
Reactions: Irun
You shouldn’t have to change your card number. Just call your credit card provider and cancel the order through them. Explain the situation and they should take care of it.
Reactions: B00mb00m
