2005 LJ Track Arm Frame Side Mount Repair
AmanAboutAhorse
Albuquerque
Hello all.
I have a 2005 LJ that I’ve owned for 7 years. It has what seems to be a 2” lift installed by the previous owner. Over the last couple years the steering has felt to get a little loose and i occasionally get death wobbles after going over a bump in the road traveling at 30ish MPH. The frequency of it happening has increased recently where I stopped driving it until I could address the problem.
I replaced the track bar a while ago, and got a JKS adjustable track bar so I could swap that out. When I removed current Unit from the Jeep and got the 9\16 drill bit/hardware out to test fit, it slides into the slot with a lot of play. I measured the bolt that came Off the Jeep and it’s 15.8mm. I was under the impression that the track arm currently on the unit was stock. There also seems to be a bit of marring on the inside of the slot (photos attached) perhaps from previously being drilled out.
  • Does anyone know of aftermarket track arms with hardware bigger than 9/16?
  • Is my only option to have a shop cut the Frame Mount and create a new one? (I don‘t have welding experience)
    • Does anybody have a shop recommendation for the Albuquerque area?
I had a hard time finding much about frame side bracket and this is all I have seen thus far.
https://genright.com/products/tj-lj-trac-bar-mount-frame-side.html
Any help or recommendations are greatly appreciate!
Thank You!
looks like someone almost broke their wrist with a drill. they work better if you can hold um straight.
and i really don't remember my stock bar but pretty sure they didn't give us what appears to be rebuildable ends like that from the factory, did they?.
That isn't a stock trackbar. Maybe some more pictures of the old trackbar itself?
If I recall correctly, when I installed my currie/rockjock track bar, I had to drill that hole to 5/8.
Hello all.
Thank You!
Tighten the bolt all the way. There won't be any slip.
Reactions: DuncLJ
thanks for the replies. I just got home from work.
I reinstalled the track bar back on the Jeep while I was figuring out how to proceed.
here are some photos of it installed. There are not any markings on the trackarm from what I can tell.
the bushing is rebuildable.
What was your torque wrench set to?
I believe the Torque spec for the Frame side mount is 110-125 FT Lbs and my current torque wrench maxes at 70. I was frustrated when I saw the frame had already been drilled out so I just reassembled everything, didn’t torque it, and haven’t driven it since.
Good reason to buy a new Torque Wrench.
I’d like to rebuild the Bushing if I could figure out the MFG then properly torque it and test drive it.
Thanks for your reply.
Your immediate problem is entirely with your torque wrench.
That looks like a Currie/RockJock track bar because of the offset Johnny Joint with a small gusset at the frame end. Look for a CE##### stamped on the black part near the axle mount.
