schmoupe TJ Enthusiast Original poster Supporting Member Joined Mar 12, 2018 Messages 156 Location NJ, USA May 12, 2022 #1 Price 15 Location New Jersey Sold the Jeep and while cleaning up, found a couple of Spicer U-Joints. Never used. Spicer 5-1330X U-Joint (SPR 539 writing)
Moab TJ Expert Supporting Member Joined Dec 15, 2018 Messages 3,255 Location Bohol, Phillipines/El Segundo, California May 12, 2022 #2 I'll take them if price is for both and shipping to 90245 is reasonable. Thanks.
T TRE3TOP Guest May 12, 2022 #3 Back up dibs. They’d prob go in a flat rate box. I’d recommend some electrical tape around the outside to hold the caps in place.
schmoupe TJ Enthusiast Original poster Supporting Member Joined Mar 12, 2018 Messages 156 Location NJ, USA May 12, 2022 #4 Shipping should be about 10 box for those flat rate boxes as long as they fit in one. Lmk if you want to move forward
Moab TJ Expert Supporting Member Joined Dec 15, 2018 Messages 3,255 Location Bohol, Phillipines/El Segundo, California May 12, 2022 #5 schmoupe said: Shipping should be about 10 box for those flat rate boxes as long as they fit in one. Lmk if you want to move forward Click to expand... Pm sent.
Moab TJ Expert Supporting Member Joined Dec 15, 2018 Messages 3,255 Location Bohol, Phillipines/El Segundo, California May 12, 2022 #6 I should have asked. Are these correct for a 99 TJ AT 4.0?
Moab TJ Expert Supporting Member Joined Dec 15, 2018 Messages 3,255 Location Bohol, Phillipines/El Segundo, California May 12, 2022 #7 Actually these aren't for my Jeep TJ. I'll pass them along to the next poster. Tre3top they are yours. My apologies. Reactions: TRE3TOP
T TRE3TOP Guest May 12, 2022 #8 Moab said: I should have asked. Are these correct for a 99 TJ AT 4.0? Click to expand... Yes. All 3 joints on the front DS, the joint at the rear axle and if you have an sye it will work for those too.
T TRE3TOP Guest May 12, 2022 #9 TRE3TOP said: Yes. All 3 joints on the front DS, the joint at the rear axle and if you have an sye it will work for those too. Click to expand... Wait nvm these are 1330s not 1310s. They won’t work for mine either.
Moab TJ Expert Supporting Member Joined Dec 15, 2018 Messages 3,255 Location Bohol, Phillipines/El Segundo, California May 12, 2022 #10 TRE3TOP said: Yes. All 3 joints on the front DS, the joint at the rear axle and if you have an sye it will work for those too. Click to expand... Now im getting conflicting info. I made a thread about that. And someone said these were for tj rubicon. Edit. I see your second post now. Yes. Lets pass these along to someone that can really use them. Reactions: TRE3TOP
T TRE3TOP Guest May 12, 2022 #11 Moab said: Now im getting conflicting info. I made a thread about that. And someone said these were for tj rubicon. Edit. I see your second post now. Yes. Lets pass these along to someone that can really use them. Click to expand... They are. I misread.
schmoupe TJ Enthusiast Original poster Supporting Member Joined Mar 12, 2018 Messages 156 Location NJ, USA May 12, 2022 #12 Ok folks, any takers?
mrblaine Crew Member Supporting Member Joined Nov 20, 2015 Messages 33,700 Location Quail Valley, CA May 12, 2022 #13 schmoupe said: Shipping should be about 10 box for those flat rate boxes as long as they fit in one. Lmk if you want to move forward Click to expand... They will both fit in a small flat rate.
JMT The Silver Fox 🦊 Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 27,642 Location 🌎 May 30, 2022 #14 schmoupe said: Ok folks, any takers? Click to expand... I’ll take them. They’ll work in my 05 Rubi.
schmoupe TJ Enthusiast Original poster Supporting Member Joined Mar 12, 2018 Messages 156 Location NJ, USA May 31, 2022 #15 JMT said: I’ll take them. They’ll work in my 05 Rubi. Click to expand... Good man. PMd you
taylormade73 Life in the way Supporting Member Ride of the Month Winner Joined May 1, 2019 Messages 4,461 Location Miami Valley Jun 11, 2022 #16 Did jmt buy these?
