I have 35s on 4" backspaced wheels and a manually operated sway lock. The tire rubs the lock at full articulation, full steering lock.
Please fix that issue. I hear MC has a solution.This is mine. 35x12.5 with 3.75" BS, no steering stop extension. It rubbed at the first hole before I pushed the front axle forward. Now it rubs at the movable plate.
The SwayLoc absolutely sticks out more on the passenger side and will cause more interference…JJ - since I believe you ran the anti rock as well, does the swayloc stick out farther from the passenger side frame than the antirock? I would think it does, but I don’t know for sure.
Given the OP is rubbing the antirock already, the Swayloc could be worse given his current setup - even without the air cylinder.
35x12.5 with 4" BS, this is where mine rubs.
I have mine pointed as up as it will go without running into anything at full stuff, specifically to minimize this contact.
My wheels with 3.75” backspacing and 33x12.50” tires just kisses the manual SwayLoc’s sliding mechanism from what I consider normal street driving. Haven’t had the SwayLoc off-road as of yet but I’m not overly worried about it…
Yea but I am running 35x12.50 so I think it may rub a bit more. Also the Swayloc looks to be thicker since it looks to have about three layers of flat steel bars. So thinking I might be rubbing even more due that fact
You had me wondering where my sway bar link went to until I realized that's an old picture.
Yea I found that picture as it showed all of the pieces that make up the unit other than the missing sway bar link
You are absolutely correct. You’d need to push the wheel/tire away a bit to clear better most likely…
Or let the tire rub and not worry about it.
