Completed my swap yesterday. It all went smoothly. So far it drives well and I am glad I did it.
I did buy a Luk clutch set and installed it.
The Novak bellhousing came with the clutch fork, clip, and pivot ball. I used the throwout bearing from the clutch kit.
With regard to the length of output shaft of the transmission going into the NP231, I did not measure them but the AX15 appeared to be out 1/4" to 3/8" longer than the NSG370 output shaft, there was plenty of clearance in the NP231.
The NSG370 transmission mount lined up just fine. I sent the one I purchased from Novak back as I did not need it. I also returned the
pilot bearing since I used the from the Luk clutch set. The picture below is looking up at transmission mount studs through the skid plate(AX15 as installed), the washer marks on the skid plate are from the NSG370.
I did have to notch the transmission mount to clear the bolts on the AX15 (the two bolts at the top of the picture below).
I did have to buy different 4 bolts, 7/16-14 by 1 inch, to attach the mount to the transmission mount to the bottom of the AX15, seen in the picture above.
The clutch slave cylinder bolted up and worked fine.
There were also three bolt that hold the shield to the bellhousing. 5/16-18 by 1/2 in. that I had to buy - the screws that came out to the NSG370 where a tapered metal screw that did not match the Novak bellhousing.
The other bolt I need was a 3/8-16 by 2in for the starter. The one that came out of the NSG370 was metric.
The Novak bellhousing has a second "port", I think for the earlier year model CPS position. I bent up a piece of sheet metal and covered that port. I secured it with two M7x1x20mm bolts and washers. Sealed it up with RTV.
I have order a boot to replace the inner boot and will adapt it to the existing one, which was torn.
The outer boot work fine.
When it was all said and done here is the list of what I had to purchase:
Novak:
Bellhousing $369
AX-15 w/shifter. $1690
Tax $0
Shipping $110
Rockauto:
Luk Clutch Kit - $159+shipping and tax
Local hardware store:
4x 7/16-14 by 1 inch bolts
1x 3/8-16 by 2 inch
3x 5/16-18 by 1/2 inch bolts
2x M7x1x20 bolt
various washer for the above bolts
AMAZON:
An inner boot yet to be tried out. $28 (I let you know how this one works out.)
Hope this is helpful to someone.
