When the time comes, mine will get repurposed for exactly that and maybe a couple larger soft shackles.
For the price I’ll just buy Blaine’s soft shackles.
this is what i also figure.
but any strap or implement that exceeds the winch lines limit then makes that line the weak point, would it be wiser to incorporate a lessor rated extension to possibly protect the main line?
The rope should be the weak point for recovery, but used within its limits.
I plan to use my old winch line as an extension as it’s far from junk.
I used the 20’ that I cut off my 100’ winch line as an extension.
How’d you treat the ends? Bury the loose end back in the rope leaving an attachment loop at the end?
Or the winch.
I spliced eyes in both ends and soft shackle them together if I need more rope.
which is not impossible. IIRC the synth lines rated better than the M8.
by eyes i assume we need devices to hold a radius on those end loops correct?
and you reminded me i still have my cutoff line drop around here somewhere.
i wanted to do a few soft shackles but then found out the force it takes to lock those knots correctly.
It's the most plausible. My rope is almost 30klbs breaking, if I recall. The TRE snatch block is about 20k. The TRE soft shackles are in the high 20klbs breaking, I think.
Very few here are running winches above 10k, with most I suspect being 8klb.
In most discussions like this one, it is often mentioned that the winch is and should be the weak point.
i thought the idea was to avoid those type of loops in synth line. i have read they need to hold a radius end and what a safety thimble was made to do.
am i wrong here? does this not apply to synth line looped to a soft shackle? the lines not supposed to be loaded on a point it's made to load along it's length, no?
I never would have guessed it was out there already.
