A/C Drain Dripping Water on Passenger Floorboard
SSTJ
Lifetime Supporting Member
South Carolina
Very basic question but I am away from my FSA right now and don’t want to scroll through a PDF on my phone.
Water is collecting on my passenger floorboard. The pic below is taken from the perspective of the passenger’s shin. I assume it is some kind of condensate drain for the AC. Where it meets the firewall, there is a spongy gasket, and if I push on it, more water drips out.
Second picture shows where the line comes out, which is where I assume all the water should be going.
Am I most likely looking for a clog, or for a crack in the line? Any other advice from others who have solved this?
I had the same issue, assuming the drain is clear. Spray-on flex seal inside and outside (don’t seal the drain) of the foam gasket fixed it for me.
Reactions: SSTJ
I bought a PVC elbow for 89¢, then drilled out the interior to just over 5/8". It fit snugly, and I wrapped it in Gorilla tape.
We'll see if that solves the problem.
Reactions: Rygrego
It'll work. The problem is the when it drains out it runs back along the tube and into the floor. I took mine in couple times and the dealership couldn't find anything wrong. Took my redneck cousin 10 secs to figure it out. In 2000 they angled it down.
Reactions: SSTJ
I learned recently that there was a TSB about this problem. @mastergunnera8 posted a link to what appears to be a $20 official fix, but my $1 elbow connector is working fine.
Reactions: Noxid
