I can say with certainty as I don't have a YJ.Sorry to ask , but is it the same by the Yj ?
I want to say it's @Brantley who has a YJ, but I could be wrong.
I am planning to do tie rod swap this weekend and set toe in. This may be a dense question but I am assuming you mark wheel width (33 in my case) from the wheel it selfy on aluminum tube and then mark center of that width on tube and then center it on rotor as shown by @Nashorn101 above. Sorry but just want to be crystal clear on it.
I had another question on this topic. Last time I did my alignment I had my tires off and some straight steel up against my rotors. When I stretched my tape measure in front I noticed that since the tires are not supposed to be parallel, but slightly toed in 1/16" over the rear measurement, that the farther I moved my tape measure away from the rotors toward the front of the Jeep, the smaller the distance becomes (simple geometry, the two theoretical lines would eventually converge), and vice versa in the rear. Therefore, at what distance in front of the rotor and behind the rotor should I measure? I hope this is articulated clearly enough to know what I'm asking.
If you want to get really specific measure your actual tire. I have 31 inch Duratracs that are more like 30 inch. so not that one inch would make that much difference, but if you are OCD measure the tire, don't take the word for it on the side of the tire.
the easiest , quickest way i found is toe plates , made by longacre racing products. it takes less than 3 minutes to check without removing the tires . i use this on my race car always without failure.
Toe Measurement Tools
View attachment 27655View attachment 27656View attachment 27657
Click image to enlarge
Toe Plates with Magnets
