Or even "only Jeeps" you know the Jeep porn site :ROFLMAO:
This IS the Jeep porn site. I caught some puss watching it. I think he's the one who hacked my account and posts crazy stuff. Tell @NashvilleTJ I found the hacker. 🤫
Well, technically this happened yesterday, but Baby got new shoes.....Went from 33-10.50-15 BFG Mud Terrains to 33-10.50-15 BFG All Terrains..... Mud Terrains were starting to crack and the fronts were worn down pretty good..Thought I might as well get new ones before winter....Much quieter, but speedometer is off by the same 10%....Need to find some mud to see if they are worse....
And maybe I should start a new website.. Jeepharmony.. bringing Jeeps and people closer together!!
Have you seen the name of the new movie...”Bros”
It really ain’t in line with what we were trying to get going on
Reactions: John Cooper
Took the "old" ZJ upgrade steering off the 97 and moved it to the 2002. Then put a new drag link, TREs, and Rough Country heavy duty tie rod on the 97. I didn't have any issues with the ZJ tie rod, but I had a friend who had the rough country tie rod and (a) it looks even beefier and (b) he drives like an idiot and the thing is still drives straight. I needed to buy something, so this felt right.
Had an apparent camber issue on the 2002, plus really uneven worn front tires. I knew the steering was shot, hubs were also shot. Replaced all that, and put the back tires (which had no wear issues) on the front, and boom, my camber problem went away. I guess the tires were so uneven that I'm guessing the ball joints would allow the tires to ride like /O|||||||O\. The hubs, shot steering, & likely bad alignment caused the bad wear. Better this than a bent axle...probably. Although a used dana 30 is probably cheaper than 2 new 33" m/t's.
Managed to free the one O2 sensor in my 2005 that seemed welded in prep of replacing all. Put a little atf around the bung and started the engine to get it hot...you could see it bubbling as it seeped into the threads. Got it to move this morning and with many back and forth movements it is finally free and ready for a new sensor.
Really want to know what brand METAL CLOAK $250.00
A machined piece of aluminum with china led lens, they made a fancy tail light.
Got a thumbs down on this post and all I can say is if you have to have the LED products then buy them from china and don't reward the businesses that import all this china crap, although I think it's a losing battle. If you "can" get them from Taiwan not mainland communist china.
Triggered? Simple question was asked is all. Lol
