After a year what I did
CptnMurica
arkansas
I’ve been so busy out wheelin here is where I’m at. Holding for now.
I’ve been lurking around here awhile. This is all stuff I got from info on this forum.
I run a lot of forest roads and have spent time at Smorr, Rush Springs ORV, 3b Offroad and Hot springs ORV. This thing gets around real good and allows me to hang a bit somewhat with rocks as long as it doesn’t get real crazy.
4.56 re gear
33 10.5 7 10-12lbs depending.
Rubicon sized flares
Keeps mud down which I avoid like the plague if possible
Rs5000x need to cycle
Works as is
Arb front
Open rear(35)
Warn winch
2” bds springs
Front at 14.5” length
Rear 11” 😮
Saavy 1.25bl
1” mml
Saavy cable shifter
Works real smooth.
Saavy gts 👍
I recommend
Steel front/rear bumper
I need to install my throttle adjuster asap.
For what I know is considered a middle build it gets around crazy good. Using as intended. Still low an tight. If anything seems could use a little weight in the rear.
This stuff has been crazy expensive.
I gotta do something with my 35 to prepare for an arb eventually, meh. 🤷‍♂️
Imma get through somehow.
4.56 re gear
Works as is
Arb front
Open rear(35)
Warn winch
2” bds springs
Rear 11” 😮
Saavy 1.25bl
1” mml
Saavy cable shifter
Works real smooth.
Saavy gts 👍
I recommend
Yeah buddy! I remember those days. Good wheelin’. That setup will take you a long way. It’s super fun too! 😜
Ikr. Lol. My dollars per intended use/fun is about maxed.
