PSA: Mopar radiator (55037652AA) has been discontinued as of late October, 2022
Well, to be precise - the radiator is a cooler, not a chiller…
The coolest cooler
I ordered from Vivid Racing today ... but not liking the email I just received from them.
Your order has been processed and is scheduled to be drop shipped directly from our vendor or manufacturer. Once we have your order tracking number(s), we will send you another email with them over so you can follow the progress of the shipment.
Please be aware due to continued worldwide supply shortages, your order may take longer to arrive. We will provide you an eta should your item(s) be backordered. For urgent or time sensitive items, please reach out to us so we can try to accommodate your needs.
  • Wow
Reactions: Jerry Bransford
I picked up my new radiator a few hours ago. On the way home, I stopped and got 2 gallons of G-05 coolant (NOT 50/50) and a couple gallons of distilled water. I plan on swapping tomorrow.
What else would you all suggest I do along with the radiator swap?
Last time I swapped radiators was only about 5 years ago. At that time, I also installed new upper and lower radiator hoses. They both still seem to be in great shape, so I'm wasn't planning on doing those. I'm on my 2nd thermostat which I swapped about 8 years ago. Should I do a new one now? Heater hoses? Water pump? I'm not having any cooling issues.
Suggestions appreciated.
Installed the new radiator today. All went well, as expected. Now to find a spare after you guys have snatched them all up. I probably should have waited a couple days to post this. 😉
Reactions: Apparition
Did you replace with Mopar or aftermarket? I’m in a bind right now and it looks like the quickest I can get a Mopar is over a month away. This won’t work. If you did get Mopar where did you get yours from? Thanks
Anyone ever have any luck determining who made the OEM Mopar radiator? So many clones out there that look near identical.
This really makes me happy I already replaced mine and kept the old because it wasn’t leaking.. could have gotten by with just a evporust flush and been fine…
My guess would be Magneti Marelli. One of the Mopar sites has a spot to order but you have to order a pallet of 25 and says it's Magnetti Marelli. It's discontinued too though. Pretty sure I remember they also made my heater core
What is the difference between OEM MOPAR radiator 55037653....AA....AB and AC.?
