Disk Brake Caliper Bracket Needed
Rex2022
Lifetime Supporting Member
Peoria, AZ
One of the holes in the front passenger side disk brake caliper bracket is stripped out. I have looked far and wide and have not been able to locate one. Does anyone know where I could find one?
Thank you!
I chassed the stripped hole with a m8x1.25 tap and reassembled it. I torqued the bolt to 11 ft. lbs. and it appears to be holding. The issue is I'm not sure how much of the thread is left in the steering knuckle, it threaded on well enough. Also, the tap, while it threaded easy into the hole, now has created a little looseness with the bolt. Meaning, I can wiggle the bolt a little bit prior to it being hand snug. Again, it did torque down just fine, but I'm not sure how much I trust it.
Would a helicoil kit work ? I can get one from under $20 and can have it hear tomorrow.
