The vivid racing site is the one I spoke about in my OP. I didn't call to verify since I found one locally.
Well, to be precise - the radiator is a cooler, not a chiller…
X2. Usually they come already capped.If you have a manual you can run the auto radiator. Just cap off the trans cooler fittings.
Installed the new radiator today. All went well, as expected. Now to find a spare after you guys have snatched them all up. I probably should have waited a couple days to post this.
Anyone ever have any luck determining who made the OEM Mopar radiator? So many clones out there that look near identical.
Did you replace with Mopar or aftermarket? I’m in a bind right now and it looks like the quickest I can get a Mopar is over a month away. This won’t work. If you did get Mopar where did you get yours from? Thanks
Should have sent him a PM. One of the thousands of peorple passing through this board will poach it.RockAuto shows they have one left in stock.
Now just Marelli.My guess would be Magneti Marelli. One of the Mopar sites has a spot to order but you have to order a pallet of 25 and says it's Magnetti Marelli. It's discontinued too though. Pretty sure I remember they also made my heater core
