How can I stop this transfer case leak?
John’o
Tucson AZ
I have a leak on my transfer case. Started leaking at same time SYE drive shaft seal started leaking (kid drove the TJ so I suppose he smacked something hard). The O-ring was munched when I removed and replaced the 1st time. I replaced the O-ring three times.
It leaks with little to no torque,
It leaks with mid-level good-n-tight torque,
And It keeps leaking with Plenty in of torque.
Questions: What is the correct O-ring? Should I get a copper crush washer?
Should I get a new plug?
What is correct torque?
Links for what to get are much appreciated.
Are you using an oil-safe O-ring, or one for water pipes? Is there a burr in the SYE housing, or on the speed sensor?
Probably a water o-ring. Will assure next one is oil rated. No burs. Did inspection yesterday.
The speedo sensor is actually 2 pieces, and there's another o-ring on the inner piece...which you don't even realize is a separate part until you do the work. I had a leak in the same spot and it was resolved when I replaced it. This is from a 97 from it's similar on other years.
Mia culpa. It is not leaking from the speed sensor. The leak is from this plug. Any idea what it is called?
oh that's the selector shaft...I've never understood why that was built that way. Yeah, I would just RTV it if you can't make the o-ring not leak.
Reactions: John’o
Huge thanks. I don’t mind RTVing. I used to work on 40 year old Helos. Just don’t want to do something silly out of ignorance.
Also ensure the vent hose isn’t plugged, if it is, it could be pressurizing the case and pushing oil out of the weakest link.
It is for a switch that was used on YJ/XJs.
