Reducing Exhaust Heat (Under Tub, Not Inside)
If you have to replace the cat you might think about getting something like what I'm using.
https://www.magnaflow.com/products/091-1016-catalytic-converter-federal-universal
It would have to be welded in but smaller than stock. Of course this only works if you don't have to be emission tested.
Also I'd check around and see if you have a local shop that does ceramic coating as it really wasn't that expensive.
Your other option would be to pull your tub & spray the underneath with Lizard Skin.
Sorry I missed this. Thanks for the ideas.
You could run one on either bank 😂
I don't remember what the exhaust pipe size is on the 4 popper but I doubt it's large enough. And why would I want to add more cats to my exhaust?
And yes I know you're just trying to be funny....
And why would I want to add more cats?
Reactions: FarFire70
Thanks for all the replies. Updated the OP with my findings.
