Couldn't find the "what i'll do to my TJ tomorrow" forum so I'll ask here.
Code P0158. And i did see where I'm to replace 1,3 or 4 O2 sensors. I'm a 2002 with the 4.0. How many am I replacing please. And must use NGK
Went scouting for trash in the woods in preparation for an Earth Day weekend cleanup...hosed off the Jeep and more WD-40 in the speedo sensor plug to displace water from snow wheeling over the weekend...and tightened a couple of retaining bolts on the track bar and rear control arms.
I'm glad you got it out! But, man, it hurt to watch that... :)
I realize that I didn’t post it here, but the seat latches were already broken from the PO putting it in. I thought it was just stuck when I first posted today, but they were mangled beyond help. I only resorted to yanking and cutting once I realized it was broken. I didn’t just destroy a perfect seat.
Spent the weekend chasing a few possiblities for a P0303 code. New spark plugs gapped at .040 and properly toqued smoothed out the idle and starting. I noticed that my power steering line is leaking right onto the connector and O2 sensor below it. Bought some electronics cleaner and power steering stop leak to see if that might clear up some more.
I've also been having an intermittent issue with the Jeep stalling when coming to a stop, so I bought a tool to check my fuel pressure, but got the unlucky draw and my fuel rail does not have the shcraeder valve. I've been searching, but I'm not having much luck seeing how to hook it up. Should I just do the fuel rail swap to the schraeder equipped fuel rail?
Also have evap codes P0442, P0455, P0456, and P1494. Going to assume that much vacuum leak isn't helping anything run smooth either.
You can buy a hose that has a schrader valve on it. Unhook the lines and put the hose in place. I don’t think it’s meant to be permanent though. Can’t remember where I got mine, but I can look when I get home.
Probably could make one for cheaper than I paid for mine if you know what to buy, which I’m sure some on here do.
I don’t remember where I got this. Somewhere online. I just got it thinking it would be good to have on hand if I ever need to check mine. Someone here probably knows what you’d need to make your own.
A 2002 4.0L should have 4 O2 sensors. 2 for each bank of manifold cat convertors.
Reactions: John Cooper
Yeah but their starter will probably last the rest of the jeep's life. I've swapped out a 1/2 dozen autozone starters when I was in high school. I'm too old for that nonsense now.
The shop probably buys their starters from Autozone, or likely Napa... which will last about 2 months longer lol. I went through 3 Autozone alternators in 1 month on my 2000 XJ. The 3rd one I was about to throw through their window before just buying a Mopar alternator. Lifetime warranty is meaningless when you have to replace the same part 3 times. On the positive side I got really good at changing alternators on Cherokees while laying on the ground in the rain.
Code P0158 description and possible causes (caveat: these are from the 2005 Powertrain Diagnostic Procedures Manual, and are likely the same for your 2002, but the PCMs changed in 2005, so there is a chance it's different):
So, the first part of that image above tells you the why - the PCM is sensing that Sensor 2 of Bank 2 voltage exceeds 3.99V for at least 76.8 seconds. Then, the second part gives you some insight into the possible causes, which can be reduced to three things:
1. A wiring issue (shorts to voltage or open circuits)
2. A faulty O2 sensor
3. A faulty PCM (ask @Wranglerfix if the P0158 code is a common PCM problem for your vehicle)
You now have two different approaches to solve the problem:
1. Throw money at it (this is not stated tongue-in-cheek, it may be the best path for you)
2. Diagnose it properly and then replace/repair parts
There's a diagram in the first post of this Resource thread that explains which one is Sensor 2, Bank 2. There's a lot of other good info in that thread, too.
If you want more help, I'd suggest starting a new thread because this thread is very active, and posts get lost easily.
