High Folks, I have upgraded my front axle to HP30 from XJ.
I measured the driveshaft angles VS pinion angles,
And I see the following:
Driveshaft at 0.4 degrees
Pinion at 3.8 degrees
That gives delta of 3.4 degrees.
I suspect that it is too much of an angle for a front driveshaft.
If I understand it correctly, it is supposed to be like 0 degrees difference, not 3.4.
The reason I started to dig into it, is that I see too much of a play in the yoke and the pinion seal is leaking.
Do you guys think that this could be related to bad driveshaft angles? I am thinking that after upgrading to HP30 I did not change anything in control arms etc.
