Size on trail is going to be an advantage or disadvantage depending on the obstacle. If wider than more stability. That could go either way though. If longer then same story. Sometimes I want longer and sometimes I like shorter. Sometimes I want wider and sometimes I want narrower. The TJ is a good platform. You can manipulate it some as tire size grows to make it better. My .02c.
