Repaired. Plugged for now until I go get a new head or manifold.
Pressure decreases suddenly then I walk around and notice puddling water
so not too difficult to find. Groundwater should be much deeper for you up in Evergreen. I should put meter on and see what pressure is, I know at the spigots it's 70 psi
Have you been having trouble finding leaks with how wet it's been? We have a dozen or so spots that we've been trying to figure out if they're leaks or just ground water all season. We've also only had to water a handful of times though. Although we definitely knew when we had a whole head pop off a swing arm and shoot a geyser 20 feet into the air directly in front of the clubhouse. 150 psi is a lot of pressure.
I think the fescue should come in fine, although it might be getting too hot. Definitely update if it does germinate.
