Torx socket broke in screw head!
nitrofalcon
Waynesboro, VA
New member to this wonderful forum. I'm in a pickle. In trying to remove the lower door hinge, the tip of the star socket (t40) broke in the very stubborn bolt head. I think the paint over the bolt contributed to the difficulty in removing. Any ideas how to get it out? I've attached a picture. I really appreciate any help.
Try to carefully tap the broken tip to loosen it up then take a magnet and fish it out. In other words get the broken tip centered in the fastener head again instead of being hard pressed against the edges. Make sense?
Same as above. I’d try a few things to try and move it so it would come out easier. If that doesn’t work could drill the center and insert an extractor to back it out.
Reactions: Kurt_S
That has happened to me, complete with the trail left on the hinge left by the broken stub. I ended up welding a bolt to mine, it came out easily after that due to the immense heat generated by the weld. Any welding shop can do that for you cheaply if you don't have a buddy who welds.
I doubt that particular bolt will come out with an extractor, they're firmly held in by LockTite which needs heat to loosen sufficiently.
There is access to the nut plate on the backside correct? Focus your heat there so you don't ruin the paint on the outside.
This is after you remove the broken socket tip of course.
Thanks for the suggestion. Attempted that, but its pretty tightly wedged in there and seems pretty well centered. It's flush with the surface so, can't even get a tapping edge.
Try smacking it dead center of the broken tip
Looking at my own picture I see now that it may possibly be centered. I'll try again.
Drilling is certainly and option. I've considered that as well. Will give it a try it nothing else works.
Ouch! I pray it doesn't come to that. I think the high heat will probably ruin the surrounding paint and possibly some other things inside footwell? I'll keep in mind if it doesn't budge.
Reactions: Jerry Bransford
Thanks, Got it. I'll keep that in mind.
You will need a punch or the corner of a chisel to get in there to hit it. In the photo, it's not centered, it's wedged in counterclockwise.
You are correct sir. I noticed that as well after looking at my own picture. I think this will be my first attempt at it since it seems the safest and easiest. I'm getting out my extra large prayer rug!:LOL:
