I just looked. My TJ manual says 5w30 is preferred.
Those anti-Fram webpages on the internet are just old wive's tales. I used to believe the same thing but learned I had been wrong for years.I use Valvoline, and any filter but Fram.
Yours a 4 cylinder? 5w30 is preferred, the 4.0 is 10w30.
Those anti-Fram webpages on the internet are just old wive's tales. I used to believe the same thing but learned I had been wrong for years. http://*********************/f282/e...s-r-and-d-facility-in-dayton-ohio-111282.html
Edit: I just noticed Chris is still censoring names of other forums... substitute those asterisks for Wrangler Forum with no space between those two words to see the writeup on my visit to the Fram R&D facility in Ohio years ago.
I switched all three of my vehicles (Jeep/Lexus/BMW) to the Fram Tough Guard years ago, it's actually a very good filter that has a higher filtration efficiency (99%) than many far more expensive filters that often only have a 95% filtration efficiency.
The key to protecting our engines is simple... change your oil and filter at reasonable intervals. Personally I use dino 10W-30 year-round here in SOCAL. I would switch to a synthetic during the winter if I lived in an area that got super cold like North Dakota, Alaska, Minnesota, etc. since that is where a synthetic's key benefit is... it flows better in extremely cold areas.
True but did you miss the note just above all the photos that Photobucket stopped displaying? There's a fix to most browsers that causes the Photobucket photos to start displaying again. I can see them.Jerry, that sucks all your Photobucket photos no longer work! What a bummer.
Jerry do you know what that setting is...drives me nuts with the stupid cat hanging down where the photo should be.True but did you miss the note just above all the photos that Photobucket stopped displaying? There's a fix to most browsers that causes the Photobucket photos to start displaying again. I can see them.![]()
I'm not following what you're asking. Setting? Cat?Jerry do you know what that setting is...drives me nuts with the stupid cat hanging down where the photo should be.
It's not a browser setting, you add an extension to your Chrome or Firefox browser.the setting in the browser you where talking about above
I use to run nothing but Castrol but seem less picky these days.
